Hey I accidently messed up my firmware installing a pkg that I don’t think is meant for this and I think I’ve corrupted SD but when I’m re-installing via the Raspi imager, the pifi image again it won’t boot
Any solution or I need a new SD card?
Try flashing the universal image on Raspberry Pi imager, it will also fix any damaged partitions too so should do the trick if there’s life in the SD Card (allow an extra 60 seconds or so to boot). Download is here:
That worked perfectly! Thanks
