The PiFi Kit, Quick Start Guide, has an activation code sticker on the front. What is that for? And, where does the user input that code?
You input it on the homescreen of the app (I highlighted where to tap in green)
PiFi Kit users get early access to new features and some features will also only be available on PiFi Kit too so activating it will unlock that. There’s a feature called Magic Config coming out in the next couple of weeks for PiFi Kit users specifically. Will also post it on the forum when it’s live.
For some reason I can’t find the page you reference?
It should be the top of the home screen when you open the PiFi app?
Are you using the app from pifi.org/app
Can you screenshot what shows when you’re on the app?
