Loving PiFi so far - many thanks and great work!
I’m interested to know if you’re planning to add the ability for the internet connection to be automatically terminated if the VPN disconnects.
Thanks again!
Thanks again!
Lots of features planned - can I ask if you’re seeing an issue where VPN disconnected but you weren’t brought offline?
If so, which protocol where you using? OpenVPN or WireGuard?
I haven’t actually tested vpn yet as my provider doesn’t offer downloadable WireGuard config - so it will be OpenVPN.
From what you’ve said it sounds as though this functionality exists already…?
It should do - I have to say personally I’ve tested a sort of “kill switch” feature far more in Wireguard than OpenVPN
If you find any issues with that, please let me know either here or by reporting a bug
