I’ve bought your kit and its working very well. I have been trying to get an edup ax3000 wifi adaptor to work but it seems to be blocked somehow. I’vd installed the drivers etc and it works on vanilla openwrt. I just want to compare the speeds its not important.
Nothing is blocked. Driver support is just exceptionally difficult on OpenWrt.
If AX3000 drivers worked well, I would sell an adapter that is AX3000
I haven’t been able to get any working thus far, probably needs a lot of driver modifications to do so
If it works on latest OpenWrt then it’ll come to PiFi, we don’t remove any support at all. But it probably doesn’t work on those build either.
