Can no longer connect to Wifi
The device worked wonderfully up till now, and perhaps I tweaked one thing too many, and now I can connect to the PiFi using the network it creates, but the device itself doesn’t connect to the wifi internet. I tried different wifi networks, different routers, doesn’t connect, so it doesn’t seem to be related to the specific wifi network I’m on. Something broke and I can’t figure out what. I tried restoring previous backups, went back to a backup which I’m 100% sure worked well, and it still doesn’t work.
I customized it so much that I really don’t won’t to completely reinstall the device from scratch.
Here’s literally everything I tried so far including the logs (with passwords redacted):
If you have any idea what else I can try, that’ll be great (connecting it with an ethernet cable works, apparently it’s just the wifi that’s not connecting).
Wireless file looks fine (although I’m yet to dive into the logs). Thanks for the pastebin that’s helpful - I’ll have a troubleshoot for you.
  1. Are you also able to pastebin /etc/config/dhcp and /etc/config/network too
Note: Please also redact any private keys (psk) etc from WireGuard on /network
  1. Can I also verify - how are these being paired wirelessly - is it via LuCI (192.168.3.14), the PiFi app or SSH/Terminal?
  2. A reboot may also be assistive (possibly not but will dive into logs too - network/dhcp could prove useful)
A few reboots later (without changing anything) and now the hotspot wifi also stopped working. Since I’m traveling with limited abilities to debug this now, I’ll need to put this project on hold until I’m back. I’ll get back to this thread when I can. Thank you for your assistance so far.
