I make it through many of the initial steps, but then get stuck. The ethernet cable is connected to my switch when I start up the RPi. IT asks me to switch to WAN. Which i click on but then it is stuck there. I try going back and skipping that part. It then says updating timezone and it is now stuck there. If I restart the program, it forget my earlier set password. Any ideas? It is s RPi/5 with 4G RAM. I can see the RPi connected to my router at 192.168.0.15. If I try and SSH to it using root, my connection is refused.
Ok so 192.168.0.15 doesnât sound right (the default IP of PiFi is 192.168.3.14) - one thing that can happen is if PiFi is set to LAN and wired to a router it can inherit the main router IP (but as PiFi hasnât yet been setup and WAN is the default I donât think thatâs the case here)
Itâs more likely what youâre experiencing is your phone/device not communicating properly with PiFi (can be a number of reasons) - first one Iâd be checking is that you donât have a software-based VPN or iCloud Private Relay enabled as that would stop you communicating with local devices such as PiFi
Can I ask where youâre seeing 192.168.0.15 (if you go to WiFi Settings on your phone whilst connected to Pi - if you click the settings cog on Android or the blue (i) icon on iOS - what does it show under Gateway IP/Router?
I am having the same issue. i have a pi4 with openwrt installed. I just sysupgraded to pifi but kept the original settings. i am able to connect to the pi on bĂłth android and windows and surf the net. but I cannot seem to get the app to work on my android despite manually setting the default ip to the current pi ip( not xxx.3.14). Should I bother with the app? I can ssh and use the web gui. not sure why the app isnât working tough
Personally, I would bother with getting it working with app (itâs a big part of what makes it a smoother experience)
When you are setting the IP manually youâre setting this to the address you can reach LuCI at?
I would 100% recommend a clean install - PiFi has various different configuration changes and dependencies and Iâm not sure âkeep settingsâ on vanilla OpenWrt would work well, certainly possible that it would have issues.
To install clean, you can basically factory reset since youâve already sysupgrade:
Open LuCI > System > Backup / Flash Firmware > âPerform Resetâ or âReset to Defaultsâ (wording may vary).
Or if you have SSH working firstboot -y then reboot would also work
Post reset the default will be 192.168.3.14 so Iâd set that in the app (reset to default)
