First Impressions
Really quick to get up and running so very different from stock openwrt in that regard
Wireguard was really easy to configure too - literally this is hours of work of setting things up a network manually and can switch servers without deleting servers so big improvement there
Will keep posted if find bugs - only one i’ve seen so far is it did say wrong port when setting up for first time but when I tapped retry it worked fine
Pi 4 is still not amazing wireless performance with any software so I am keen to try the kit so will order it tomorrow and see if it’s that much faster because that would make it much more of a proper router. So far so good…
Awesome! Glad to hear it’s working well for you and setup is fast - I’ll also double check the port message you mentioned during setup!
