How to install it?
Can I install this on Raspberry Pi OS or using docker-compose?
Or do I flash it on an SD only?
Hey, it needs to be installed on an SD card and doesn’t currently install on top of another OS
The PiFi Kit (if you are interested in faster speeds) comes with a preconfigured SD Card if you are not able to flash it.
Also have a Setup & Download guide here if you are looking for info on how to get started
Ok will give it a try!
