IP Address Changing
I want to start off with how great this interface and simple the setup was. Fantastic work!
This may be a dumb question, but I have set everything up, used Surfshark and got the VPN running, but when I go online to see what the IP Address is on a connected device, it shows an IP from my current location and not one through the VPN. Am I missing something?
Thanks for the help,
Joe
It does sound odd as it should show the VPN IP.
On the app, it’s showing VPN as connected?
Can you try opening a private browsing tab and trying again.
Is https://dnsleaktest.com showing your ISP?
Thanks for the quick response, I wasn’t patient enough with it! Once I restarted the device it changed!
