💾 New .img for flashing (Fix for Pi Imager Issue)
We’ve updated the PiFi image to fix a flashing issue that was affecting newer versions of Raspberry Pi Imager.
I identified that installs were failing due to a strict 512-byte image size alignment requirement. That’s now been corrected.
You can now flash PiFi as normal using the latest Raspberry Pi Imager, no workarounds such as Balena Etcher needed.
If you previously ran into issues, just grab the updated image and try again:
:point_right: pifi.org/downloads
