So I stumble upon this project yesterday after which I ordered the kit right away. I couldn’t wait so I whipped out an old sdcard flashed it to test it out and all went well. I got the kit today and yanked the old sdcard out for the new card that came with the kit. Plugged the adapter in, Ethernet cable then finally the power in. Then waited and waited nothing. No blue light on the usb adapter as described in the documentation or setup wifi to connect to. I left it for almost 20mins nothing. Did I do something wrong. By the way when I put the old sdcard in it works again but not with the usb adapter (no blue light) but I got a prompt to enter the code in front of the manual that came with the kit. Please help
Have emailed you steps to check to see if adapter issue or something else. Hopefully resolves it for you.
