I’m running openwrt on Rpi4 and I like the look of this a lot but is there a sysupgrade image I can use because I am travelling and I don’t have access to a SD card dongle
also - can I keep settings from my existing setup as it runs openwrt too?
You can find a sysupgrade version on the PiFi GitHub so you can install it via LuCI
I recommend not keeping setting as PiFi has a different config and it likely won’t work with app if preserving settings - you can maybe run opkg list-installed before or take note of any packages you want to re-install (things like USB adapter support, USB ethernet, Wireguard, AdGuard, OpenVPN etc are already pre-installed on the PiFi image anyway)
That worked a treat thanks and very quick to get going. Will try on pi5 when I’m back on UK
