PI5/Kit speed lower than expected
I’m a little disappointed over the wifi speed I’m getting with the kit. Not running a VPN at the moment.
According to the Okla speed test I’m only getting 80-100Mbit using the PiFi kit with the PI5 wired to our router vs 1-1.1Gbit when connected to the router’s own wifi.
Pi5 is located about 2’ from the router supplying regular wifi.
Not sure if I’m doing something wrong.
Including some random Luci info:
From router:
Pi wired to Lan3 on the router: LAN3 Connected 1000Mbps
ID Name IP Address MAC Address Connection Type Link Rate rssi Attached To
6 Pifi 192.168.88.13 66:66:66:66:66:78 Wired 1Gbps - 66:66:66:66:66:48
Luci Status Overview:
Status
System
Hostname PiFi
Model Raspberry Pi 5 Model B Rev 1.1
Architecture ARMv8 Processor rev 1
Target Platform bcm27xx/bcm2712
Firmware Version OpenWrt 24.10.1 r28597-0425664679 / LuCI (HEAD detached at 2ac26e5) branch 25.103.51521~2ac26e5
Kernel Version 6.6.86
Local Time 2025-12-28 66:66:30
Uptime 2h 14m 7s
Load Average 0.04, 0.04, 0.06
Memory
Total Available
Used
Buffered
Cached
Storage
Disk space
Temp space
/dev/mmcblk0p1 (/boot)
/dev/mmcblk0p3 (/mnt/mmcblk0p3)
Port status
eth0
1 GbE
Part of network:
wan: !(http://192.168.3.14/luci-static/resources/icons/ethernet.png "Ethernet Adapter: “eth0"”)
▲ 421.9 MiB
▼ 871.3 MiBReceived bytes: 871.27 MiB
Received packets: 759.07 KPkts.
Received multicast: 60.01 KPkts.
Receive errors: 0 Pkts.
Receive dropped: 0 Pkts.
Transmitted bytes: 421.89 MiB
Transmitted packets: 536.67 KPkts.
Transmit errors: 0 Pkts.
Transmit dropped: 0 Pkts.
Collisions seen: 0
Network
IPv4 Upstream
Protocol: DHCP client
Address: 192.168.88.13/24
Gateway: 192.168.88.1
DNS: 192.168.88.199
DNS: 192.152.0.2
Expires: 1h 46m 51s
Connected: 2h 13m 9s
Device: Ethernet Adapter: “eth0”
MAC address: 66:66:66:66:66:78
Active Connections
Active DHCP Leases
Hostname IPv4 address MAC address Lease time remaining Static Lease
W0nka 192.168.3.217 66:66:66:66:66:9E 10h 57m 12s
Bjorns-iPhone 192.168.3.134 66:66:66:66:66:BB 9h 57m 58s
iPhone 192.168.3.122 66:66:66:66:66:91 9h 55m 43s
Active DHCPv6 Leases
Host IPv6 address DUID Lease time remaining Static Lease
There are no active leases
Wireless
radio0
Type: Cypress CYW43455 802.11ac/b/g/n
Channel: 153 (5.765 GHz)
Bitrate: -
SSID: Unavailable
Mode: Client
BSSID: 66:66:66:66:66:79
Encryption: -
Associations: -
radio1
Type: MAC80211 802.11ac/b/g/n
Channel: 44 (5.220 GHz)
Bitrate: 351 Mbit/s
SSID: W0nk3r5
Mode: Master
BSSID: 66:66:66:66:66:41
Encryption: WPA2 PSK (CCMP)
Associations: 1
Associated Stations
Network MAC address Host Signal / Noise RX Rate / TX Rate
Access Point “W0nk3r5” (phy1-ap0) 66:66:66:66:66:9E W0nka (192.168.3.217) -68 dBm 468.0 Mbit/s, 80 MHz, VHT-MCS 5, VHT-NSS 2
351.0 Mbit/s, 80 MHz, VHT-MCS 4, VHT-NSS 2
Powered by LuCI (HEAD detached at 2ac26e5) branch (25.103.51521~2ac26e5) / OpenWrt 24.10.1 (r28597-0425664679) / Lua compatibility mode active
Tail of system log:
un Dec 28 66:66:32 2025 daemon.info sh[2306]: Interface phy1-ap0 exists and is UP. All good.
Sun Dec 28 66:66:32 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:34 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:36 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:38 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:40 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: true
Sun Dec 28 66:66:41 2025 daemon.err sh[2527]: mv: can’t rename ‘/etc/sysp/usbcheck/pifi_checkusb_setup’: No such file or directory
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: Checking for the file at /etc/sysp/usb…
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: /etc/sysp/usb exists.
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: The file /etc/sysp/usb does not contain ‘0’.
Sun Dec 28 66:66:41 2025 daemon.err sh[2527]: uci: Entry not found
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: Current SSID does not match expected SSID. Detected SSID:
Sun Dec 28 66:66:41 2025 daemon.err sh[2527]: /etc/sysp/pifi_unconfigured: line 2:
: not found
Sun Dec 28 66:66:41 2025 daemon.err sh[2527]: /etc/sysp/pifi_unconfigured: line 66: syntax error: unexpected end of file (expecting “then”)
Sun Dec 28 66:66:41 2025 daemon.info sh[2527]: Path and port match. No action needed.
Sun Dec 28 66:66:42 2025 daemon.info sh[2527]: Radio1 is up. No action needed.
Sun Dec 28 66:66:42 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:43 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:45 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Sun Dec 28 66:66:47 2025 daemon.warn wpa_supplicant[1194]: phy0-sta0: Failed to initiate sched scan
Channel stats Radio0/5Ghz
Signal SSID Channel Channel Width Mode BSSID
-10 dBm Local Interface 149 20 MHz Client 66:66:66:66:66:79
-25 dBm ⬤ hidden 40 160 MHz Master 66:66:66:66:66:4A
-25 dBm ⬤ Dizzy5 40 160 MHz Master 66:66:66:66:66:4A
-29 dBm ⬤ W0nk3r5 44 80 MHz Master 66:66:66:66:66:41
-48 dBm ⬤ hidden 40 20 MHz Master 66:66:66:66:66:0D
Radio1/5Ghz
-10 dBm Local Interface 44 80 MHz Master 66:66:66:66:66:41
-32 dBm ⬤ hidden 40 160 MHz Master 66:66:66:66:66:4A
-33 dBm ⬤ Dizzy5 40 160 MHz Master 66:66:66:66:66:4A
-33 dBm ⬤ hidden 40 160 MHz Master 66:66:66:66:66:4A
-52 dBm ⬤ hidden 40 20 MHz Master 66:66:66:66:66:0D
-74 dBm ⬤ hidden 40 160 MHz Master 66:66:66:66:66:A2
-74 dBm ⬤ Dizzy5 40 160 MHz Master 66:66:66:66:66:A2
Network interfaces:
lan
Type: Bridge
Device: br-lan
Connected: yes
M66: 66:66:66:66:66:41
RX: 442.75 MB (579664 Pkts.)
TX: 935.62 MB (751161 Pkts.) (Type: Wireless Adapter
Device: phy1-ap0
Connected: yes
RX: 473.01 MB (390690 Pkts.)
TX: 957.51 MB (761116 Pkts.))
br-lan Protocol: Static address
Uptime: 2h 38m 12s
IPv4: 192.168.3.14/24
IPv6: undefined/0
wan
Type: Ethernet Adapter
Device: eth0
Connected: yes
M66: 66:66:66:66:66:78
RX: 936.93 MB (794210 Pkts.)
TX: 446.91 MB (551167 Pkts.)
eth0 Protocol: DHCP client
Uptime: 2h 49m 9s
IPv4: 192.168.88.13/24
That seems very very slow compared to what I see. I get easily 500+ with VPN on.
I get faster than you even paired wireless so that’s super low on a highspeed connection with a cable.
Can I ask for a quick check. Do you have a device with an ethernet port that can do a speed test?
To see what speed your router is really giving from that 1gbps port (going to guess that’s the issue/bottleneck)
As @jimmy86 said, it’s a lot less than you’d expect and not the speeds that it can handle
Couple of checks I’d do:
  • First, as already suggested, what do other devices get from that same port (speed test)
  • Is the wireless network showing as PiFi 5 or PiFi 5 Setup (confirms if it’s actually broadcasting from the USB adapter)
I see that radio0 is operating on channel 44 (non default channel) - have you changed the wireless channel?
Hooking my laptop up to the the same lan port on the router shows a link speed of 2.5Gbs and I get +2Gbs up/down on the speed test.
When the PI5 is hooked up the link speed shows as 1Gbs and Luci shows ethernet port status as 1GB
I have not changed any low level wireless settings such as channels. I changed the name to W0nk3r5 and it looks like radio 0 is the built in wifi which is not active. So it seems it’s using the USB adapter.
radio0
Channel: 2 (2.417 GHz)
Bitrate: -
SSID: Unavailable
Mode: Client
BSSID: 2C:CF:67:B5:AF:79
Encryption: -
Associations: -
radio1
Channel: 48 (5.240 GHz)
Bitrate: 585 Mbit/s
SSID: W0nk3r5
Mode: Master
BSSID: A0:8C:F2:02:15:41
Associations: 1
The Pi has a 1Gbps port so that is the correct rating
But I don’t understand why you would be seeing 80-100Mbps real world
I did see a channel difference from my config
Can I suggest a factory reset or PiFi and before changing any config can you redo the speed test when it’s wired to your router
I did a factory reset from the app. Speed before setup came back w 70 Mbs down/. I also did a speed test on regular raspberry pi os 64 bit and also got some disappointing results. It seems like I have some more work to do there before getting back to PiFi. But this is basically my first raspberry experience. I’ll keep you posted.
Found one of the culprits - slow and undersized SD card. Had some issues w the SD card in the PiFi so I just grabbed one in the pile and burned PiFi onto it. I happened to be a 16GB / U1 card.
After changing to a 64GB U3 card I’m getting ~230 Gbs down and ~500 up from PiFi when the Pi5 is on a wired connection. Better but still not happy.
On the pi5 itself I’m getting 500 down wired running 64 bit OS. So there’s something else not PiFi related going on. I’m still digging as time permits.
Yes, should be able to higher download based on what you’ve said so seems bottleneck somewhere
