- Sometimes the app does not list previously uploaded wg config server files that have been added to the app. I have to select “setup” again and then it sometimes lists it and sometimes I have to add it again.
- The first time it connects to a wireguard server can take a very long time. Subsequent connections seem to happen faster. Is there a reason for this?
- Often, when I tap the 3 dots to the right of a server and then tap connect, it just takes me back vpn screen where it says You’re unprotected. I tap connect wireguard again, tap the 3 dots, tap the server and again returns me to the main vpn screen. The end result is I’m unable to connect to a wireguard server. The app appears to be broken. I cleared the app cache and it downloaded it again. Then it shows wireguard connected. Then I disconnect and try to connect again. And same endless loop described above.
Not a known issue, no but let me test on latest release app and see if I can replicate.
Can I ask which VPN config you are using?
Is it a commercial VPN provider (e.g NordVPN) or something like PiVPN etc?
I have 2 servers added. One torguard and one my own hosted server.
