Love the idea of this product. I have a few Pi 4’s sitting around doing nothing and thinking this could turn one of them into a vpn travel router. I do have one concern though. I’m considering purchasing the pifi kit. I noticed the firmware comes pre-installed with adguard. I run my own vpn server and on that server is also adguard. Obviously I don’t need two dns servers and I’m thinking this could create a conflict. If I connect to my vpn server which is running it’s own adguard, will your adguard instance conflict and cause an issue? It’s a bit confusing. Is the adguard on your firmware only used if not connecting to a vpn and if connecting to a vpn it will use the wg tunnel dns as set in the wireguard config file?
This is as I understood it. Thanks for the clarification. One more question, will this work with Pi4 2 or 4gb model? And the Pi4 does run hot. Can this run ok in a case without a fan for extended periods of time? Thanks
It will work with all Pi 4 models (and with firmware that we release on likely Friday all Pi 5 models too including new released models)
With temp - it can depend, I run mine without a fan and it doesn’t run particularly hot, but have heard others saying they prefer to run with fan so perhaps depends.
One major recommendation I have for temp is to use the minimum recommended power supply (as PiFi USB is a USB 3.0 accessory so higher power draw that Raspberry Pi on its own) so for Pi 4 that is a 5v3a power supply. Using an underpowered adapter can cause it run hotter.
Would PiFi run fine on a Pi4 2gb Ram model or better on the 4gb? Does the additional ram really matter for this single limited use case? Meaning just using the Pi4 as a router. My vpn would be wireguard which does fine on minimal RAM compared to OpenVpn.
Even 1Gb Pi 4 runs fine - WireGuard more dependent on CPU than RAM so you should be fine with any (particularly with WireGuard)
I think future iterations of PiFi might have extensions where more RAM could be handy, but just now for router/VPN/ad blocking etc I wouldn’t feel the need for more RAM
