It would be great if you could offer a branded travel case made for pifi. It would store the pi5, the adapter, the ethernet cable and the power supply. It would be the smallest possible size that could fit all of that conveniently. If you offered it in the store, I would buy it.
It would be another great way to support this project.
It is a great idea! I do agree and would love to do that
I did mock up some concepts for case ideas, but if doing it in near future, I’ll post to all users and get input on potential designs
Got a few things coming for PiFi on the software front first then would love to look more at this
I like the idea of posting to users for feedback. The challenge I’m currently having with finding a suitable case is the RP5 official power supply. The cord is permanently attached making it a bit bulky and unwieldy to fit in existing cases. The other things like the Pi5, the adapter, the Ethernet cable are easy. The challenge is in the power supply. And I want to protect the Pi5 and the adapter from the bulky power supply.
