Hi, I believe you’d just add those lines to the bottom of /boot/config.txt like so:
# Bootloader configuration - config.txt
# For overclocking and various other settings, see:
# https://www.raspberrypi.com/documentation/computers/config_txt.html
# OpenWrt config
include distroconfig.txt
[all]
# Place your custom settings here.
usb_max_current_enable=1
# Enable the PCIe external connector
dtparam=pciex1
# Force Gen 3.0 speeds
dtparam=pciex1_gen=3
dtoverlay=gpio-fan,gpiopin=14,temp=80000
console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=squashfs,ext4 rootwait ipv6.disable=1
# Custom GPIO settings for auto shutdown
dtoverlay=gpio-poweroff,gpiopin=18,active_low=0
dtoverlay=gpio-shutdown,gpio_pin=17,active_low=1,gpio_pull=up
The rest of that will already be present so it’s just adding those two lines, after that if doing it whilst Raspberry Pi is powered on I’d suggest a reboot and you should be all set!
