Not so much a question but I tried PiFi on my RPi 4 just to see what kind of performance it could handle, and honestly it did pretty well. Used the default image from the download site and was easy to get going. At the moment I’ve got my Linksys router in bridge mode plugged into the Pi (using a USB-to-Ethernet adapter) so had to use LAN?WAN switch in settings, and the Pi is doing all the heavy lifting. I’m seeing speeds of 500+ with WG which is really good for my connection.
Yeah the Pi 4 is definitely very capable for Wireguard, glad to hear you found it easy to get up and running!
