I have a wireguard config file with 2 peers. The same config file works perfectly with the wireguard app on my android phone. I add the same config file to Pifi and it just spins forever and can’t seem to connect. Hope you can help troubleshoot. Thank you.
If you’re able to share the config (just redact private keys), I can take a quick look — multi-peer setups can behave differently on OpenWrt vs the mobile app. But I will have a look
To support@pifi.org - not here.
Sent email. Thank you.
Sent email per your request 25 days ago and crickets. Support used to be good here, but very disappointed in it now. You asked me to send you email, I did and then you do not reply or help.
