Hello, I’m happy to support this project, so I just ordered the PiFi Kit. But, I would like to use a larger size SD Card in my Pi. Is there anything special about the 32gb card that comes in the kit? In other words, if I use the image that’s available to download from the PiFi website, and I flash that to a 512gb SD card, will that include all the files, drivers, and other magic that comes pre-loaded on the kit’s 32gb card? In advance, thanks for your help!
Yes you can absolutely use a larger SD card and it’ll include everything you need and work with the USB adapter too
