Is there a big difference in performance between running PiFi on a Pi 4 vs Pi 5 for things like streaming and multiple devices? Wondering if it’s worth upgrading?
If you’re running WireGuard with PiFi Kit, performance is more than sufficient and roughly comparable to a Pi 5 (CPU isn’t a major factor for WireGuard).
For OpenVPN, the Pi 5 is significantly better and the recommended choice.
Summary:
- PiFi Kit + WireGuard → Similar to Pi 4 performance
- WireGuard (without PiFi Kit) → Pi 5 runs faster
- OpenVPN → Pi 5 strongly recommended
