Hi there,
While setting up my PiFi (kit) on a Raspberry Pi 4 I am running into an issue I cannot seem to fix.
While setting up the device for the first time using the app I run into an issue where the PiFi SSID is not broadcast after changing it from the pre-set ‘PiFi 4’ SSID.
The gist appears to be that the pyy-1-ap0 device doesn’t re-enable after resetting the SSID (using ‘pifi’ all-lowercase, no special characters or hidden space). The final few lines of terminal code:
Last section of initial boot sequence, after reboot to new SSID:
rt188x2bu 2-2:1.0 phy1-ap0: renamed from wlan4
start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
br-lan: port 1(pyi1-ap0) entered blocking state
br-lan: port 1(pyi1-ap0) entered disabled state
device phy1-ap0 entered promiscuous mode
brcmfmac mmc1:---1:1 phy1-sta0: renamed from wlan0
br-lan: port 1(pyi1-ap0) entered forwarding state
Followed, after configuring using the PiFi-app (Android), upon changing the PiFi network SSID to ‘pifi’:
device phy1-ap0 left promiscuous mode
And now no new SSID is broadcast (deduced by no network named ‘pifi’ showing up on my phone).
The first time I experienced this I ended up reflashing the SD-card and uninstalling the app (completely, incl. cache etc). After reflash I run into the same issue.
What can I do to fix this? Any help would be greatly appreciated.
Thanks in advance.
