Mount extra ssd storage
I seem to be having some similar issue to this post:
But that one seem to have ended without a resolution.
I’m not sure if this is really an issue or not, but I’m using an SSD connected to USB (via an Argon One case, Raspberry Pi 4).
In the app, if I go to Settings → Network Storage, I only see my SD card in the list and not the USB SSD drive.
If I go in the browser to 192.168.3.14 then to Services → Network shares, I see the SSD drive in the shares.
If I go in the Network of Windows Explorer into 192.168.3.14 I do see the SSD drive and I can read/write to them just fine.
So seems to be an issue in the app, just not showing the SSD in the list. Not sure how big of an issue this is if I seem to able to access it properly.
Great job on this software, simply amazing.
That’s good to know and I’m glad to hear you’re enjoying the software.
If it’s showing in network share and working then there may be an issue with how it’s searching for connected drives in the app. Should be a simple fix so will try and make sure it’s displaying all SSD in next update.
If I can’t recreate the issue, I might follow up with you if that’s ok to see if I can recreate/fix at my end.
Great, I would love to help debug this if you need.
