[Solved] SD broke. Help!
How do I fix corrupted SD? Using the official PiFi one. I was doing a lot of read/writes, it failed and won’t boot (sector failure or something) and even flashing the image with raspberry pi imager and image from downloads it still won’t boot.
Using Pi 4. Do I need to go buy a new SD?
Try the .img linked on this post - should handle any corruption on partitions which sounds like may have happened on your install. Shouldn’t be necessary for a new SD unless complete card failure.
I should’ve searched. that did the job thanks
