I’m currently using the beta image and it’s quite similar to the stable one, but I like staying on the bleeding edge of OpenWrt builds. Do you have any info on when the next build will be released and what changes it will include?
Hi Lance, yep - next Friday (9th) I’ll publish the current build at whatever stage it is at
Things to expect:
Current Limitations:
Recommendations:
Sweet! Sounds good will try it and report back
Available now on Pi 5:
